Thu, Nov 28, 2:45 AM CST
Subject: obj export from poser4?
Leyla ( ) posted Sat, 16 December 2000 at 7:26 AM ยท edited Thu, 08 August 2024 at 5:06 PM
hi, here is another boring question from leyla: after i exported this girl from p4, and imported it into max ( or any other program ) i got this... i used maximum pose to weld the vertices but without welding i had the same problems... comments? help? greetings from leyla
JeffH ( ) posted Sat, 16 December 2000 at 9:16 AM
It looks like you have the legs rescaled or tapered. Turn off IK and see if the problem persists.
Leyla ( ) posted Sat, 16 December 2000 at 1:12 PM
ik is off, and yes i rescaled the legs a little...
ScottA ( ) posted Sat, 16 December 2000 at 2:40 PM
When you export a figure. Try checking these options from the small pop-up window and see if it helps. To export a figure check: Include body part names in polygon groups Include existing groups in polygon groups Weld body part seams ScottA
