Wed, Feb 5, 11:52 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 5:33 pm)
Subject: How to re-enable downloading of ZIP file in XP, SP2
JHoagland ( ) posted Sat, 04 December 2004 at 12:30 PM ยท edited Wed, 05 February 2025 at 11:50 PM
I know this is off-topic again, but I think it's important enough that all Windows' user should see it. Feel free to move this message if needed, just make sure that anyone with XP, SP2 knows where to find it. :)
Apologies if this has been posted before, but here is how to re-enable the ability to download zip files under Windows XP, Service Pack (SP) 2.
If you intalled XP, SP2, you probably found out (the hard way) that Internet Explorer will no longer download zip files. You can tell if your settings are wrong if:
  • When you click to download a zip file, IE will sit and sit and nothing seems to be happening.
  • When you click to download a zip file, the file is "opened" in IE, meaning the contents of the zip file are displayed in the browser window as text characters.
    This is due to two reasons: tightened security settings by Microsoft and a re-setting of the zip file attributes (again, to tighten security).
First, you'll need to re-set the default action for zip files to "Open with WinZip":
Open Windows Explorer.
Go to Tools > Folder Options.
Click on the tab for File Types.
Scroll to the bottom for Zip files.
Click the Advanced button.
Under the "Actions" list, click "Open with WinZip" and then click the "Set Default" button.
Make sure "Confirm open after download" is CHECKED.
Click the OK button to close the dialog boxes.
Note: These instructions assume that you use WinZip to manage zip files. If you do not have WinZip (and use Windows' built-in zip file feature), then go download WinZip (it's free). :)
Next, you may need to set the "pop-up" window option in Internet Explorer so sites can "pop-up" the download window correctly.
Open Internet Explorer.
Go to Tools > Pop-Up Blocker > Pop-Up Blocker Settings.
Type in the URL of the site to allow pop-ups (such as Vanishing Point or Renderosity).
Note: do NOT turn off pop-up windows completely unless you use another software program to manage pop-ups... or unless you like pop-up windows.
SP2 also adds a new Control Panel called "Security Center" which allows you to manage your firewall, anti-virus, and automatic update settings. Leaving these in their default settings will not affect the downloading of zip files.
--John
VanishingPoint... Advanced 3D Modeling Solutions
barbie4364 ( ) posted Sat, 04 December 2004 at 2:23 PM
Hi John! Thanks for posting the info! I read your other message about the yahoo deal and it scared me into finally taking the sp2 plunge. I had just finished installing it when I came back and read this post. Talk about timing!!!! Thanks again! Lonni :)
Ardiva ( ) posted Sat, 04 December 2004 at 4:41 PM
Attached Link: http://www.mozilla.org/products/firefox/
Better yet..get Firefox. :)
MeInOhio ( ) posted Sat, 04 December 2004 at 7:04 PM
I haven't really had any problem with this. Sometimes my download won't start, and I'll see a message up near the address bar that says that windows has prevent the file from downloading to prevent harm to my pc. Don't remember exactly what the message says. Then I'll right click on it and chose the option that says download this file. I am running Norton Internet Security along with SP2. Not sure if that has any effect.
dbowers22 ( ) posted Sat, 04 December 2004 at 8:41 PM
I second Ardiva's comment. Yes, get Firefox instead. I have been using Firefox for two months now and I love it.
Khai ( ) posted Sat, 04 December 2004 at 8:56 PM
better still. never trust XP to handle Zip files. pats his Winzip
Ardiva ( ) posted Sat, 04 December 2004 at 9:02 PM
You're going to save yourself one heck of alot of trouble by using Firefox, kids. :)
Ardiva ( ) posted Sat, 04 December 2004 at 9:04 PM
Winzip I use exclusively, Khai. It's a good thing to have no matter what browser you use. :)
Jackson ( ) posted Sun, 05 December 2004 at 12:33 PM
Thanks for this info John; I saved it in a text file for when I finally install SP2.
As for ZIP support in XP, I have that turned off using this method:
"Select Run from the Start Menu.
Type regsvr32 /u %windir%system32zipfldr.dll at the prompt, and click Ok.
The change will take effect immediately, but you may have to restart Windows for all traces of the built-in ZIP support to disappear.
But that was for the original XP. Does anyone know if it works with SP2?
