Fri, Jan 10, 12:25 AM CST
Subject: Confoming Clothing Morphs the E-Z way!
Jim Burton ( ) posted Sun, 17 December 2000 at 12:53 PM ยท edited Thu, 09 January 2025 at 4:13 PM
(Supermodel Vickie tries out for the Pamala Anderson role on VIP...) I mentioned this awhile ago, and I ran into it again, and it actually does work! If you create full body morphs for conforming clothing that have the same names as full-body morphs on the figure the clothing conforms to AND you use the Curious Labs updated Poser (maybe) AND the morphs are in the same order (maybe again, I'm unsure, when you turn the dial on the figure the clothing automatically adjusts. Yes, it works, no messing with the CR2, no nothing. I'm (once again) not claiming this as a discovery, as I suspect it is supposed to work that way, just I've never seen it mentioned before. Needless to say all my Supermodel clothing will have this feature!
Ghostofmacbeth ( ) posted Sun, 17 December 2000 at 1:24 PM
Still can't figure out how to make full body mophs though S But thanks for the info
ARCHITECT ( ) posted Mon, 18 December 2000 at 1:19 AM
I didn't figure out how to make a really working full boy morph too... If I try this (I've seen many "html-guides" but seems I'm too stupid to understand it) I will see no reaction of the character if I apply the morph... This is a little bit strange because I have made some nice morphs for my ponygirls - but these are no full body morphs...
Jim Burton ( ) posted Mon, 18 December 2000 at 7:40 AM
Well, first you have to make a regular morph for a part, or make morphs for a couple of parts, or use existing morphs, then set the morph or morphs to a desired position (which will be the 1.00 setting in the full body morph), then make the full-body morph.
bloodsong ( ) posted Mon, 18 December 2000 at 9:33 AM
heyas; that happens due to a bug, actually, of poser figures reading full body morphs from figure 1 instead of their own figure. it's the same principle behind jcm/ecm, if you want to read the full details of how/why it works, you can find those tutorials... (um, around here somewhere :) )
