Mon, Nov 25, 2:38 PM CST
Subject: refraction 133...
MatCreator ( ) posted Wed, 08 December 2004 at 11:43 AM · edited Mon, 25 November 2024 at 12:05 PM
if anyone can help, i would be greatly appreciative :) at what point does water become water?!? a setting of 133 refraction doesnt always yield a "water"... why is that?!? im terrible w/ the technical end of bryce, i hope i am making sense... thanks.
There are 3 kinds of people in the world. Those that can count, and those that can't..
Rosemaryr ( ) posted Thu, 09 December 2004 at 8:49 AM
Possibility: Check on the color, transparency and reflection settings. All three will have an effect on how 'watery' the end result is, beyond the refractive index. It's a balancing act. For example, a calm puddle under a blue sky will be effected more by the sky's reflection. A rippled water will have areas that reflect what's above it, as well as areas that show the water's own qualities.
RosemaryR
"This...this is magnificent!"
"Oh, yeah. Ooooo. Aaaaah. That's how it starts.
Then, later, there's ...running. And....screaming."
MatCreator ( ) posted Thu, 09 December 2004 at 4:15 PM · edited Thu, 09 December 2004 at 4:17 PM
hmmmm... im speaking w/ regards to the dte specifically... dont get me wrong, i know a good water when i see one :D i mean at what point does the dte "decide" to call the material water when the refraction is set to 133...
what "conditions" tells bryce to -label- the refraction as water... (glass at 153 and air at 100)
Message edited on: 12/09/2004 16:17
Rosemaryr ( ) posted Fri, 10 December 2004 at 8:35 AM
AAAAhhh. I see where the question is coming from, now. Those numbers are based on real-world numbers called the Index of Refraction, which is pretty unique for almost all subtances. A complete discussion of the mathematics can be found at: http://www.rockhounds.com/rockshop/gem_designs/refractive_index/ And a listing of the most common RI's for various transparent materials at, (as well as a Bryce rendered set of pics showing the effects of those settings): http://www.3dlapidary.com/HTML/Materials3.htm (You happened to hit one of my hobby points with this: I run 3D Lapidary.com -- in my sarcasm alert abundant free time.)
RosemaryR
Rosemaryr ( ) posted Fri, 10 December 2004 at 8:39 AM · edited Fri, 10 December 2004 at 8:51 AM
Forgot to mention:
Bryce (for reasons unknown) multiplies the RI by 100. Thus, water at RI=1.33, is shown in Bryce as 133.
Message edited on: 12/10/2004 08:51
RosemaryR
MatCreator ( ) posted Sat, 11 December 2004 at 6:08 AM
wow wow wow. thank you so much, words cannot express :D this is awesome info for me, as i am left and right brained... makes it easier for me to "do stuff" :)
