Haven't seen this one before....looks like python has not installed correctly with P5. Can I suggest downloading one of ockham's fine scripts (like the LightPanel) from the FReestuff and try running it. If they both don't work - then it's a P5 python problem. Let me know what happens....
Message edited on: 12/21/2004 22:45
Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
PC or Mac? Python has known issues on Mac (TKInter apparently doesn't work well).
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
Ajax: it's a pc randym77: I've reinitialized Python several times and I've exited out and gotten back in. The only thing I haven't tried is trying it again today after having the computer off all night... I've downloaded one of ockham's light scripts but don't have time to give it a try just now. I'll let you know how it comes out. :)
Admin: http://www.artistsagainstcensorship.com
Artist: http://www.skyewolfimages.com
OK, the same thing happens when I try to run Ockhams light panel script so it must be a p5/python issue. I didn't install Poser 5, my husband did it for me while I was away this fall. Should I reinstall P5? Is it possible that he didn't install something correctly?
Before you try re-installing poser, have you added the script to the python script list? I've found running scripts from there to be less of a problem than using the run command under the File menu, it's something to do with the long file names & the amount of folders poser has to dig into to get to the script.
Windows 7 64Bit
Poser Pro 2010 SR1
Lucifer: yep, tried both ways and get the same result
OK, everyone, thanks for all your help :) Reinstalling P5 did the trick. I have a feeling that the install crashed (had a poorly seated vid card in the beginning with this new pc) and screwed something up with Python :) Thanks guys!!
