Sat, Dec 28, 1:08 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 9:24 pm)
Subject: Saw and lost a tutorial for fitting dynamic clothing.
Furyofaseraph ( ) posted Mon, 03 January 2005 at 6:36 PM · edited Fri, 27 December 2024 at 10:22 AM
a long time ago, before i decided to use dynamic clothing, i found a tutorial that i then ignored. It was about fitting dynamic clothing by using animating the scale of the character from 0 to 100, and thus, expanding the clothing along with it. now the problem is i dont know if this description is indeed acurate, just due to it being a while ago. Does anyone know of any such tutorial?
odeathoflife ( ) posted Mon, 03 January 2005 at 7:05 PM
sure that is accurate but you do not need to go from 0 - 100 on hte scale what I do is drop the figure on the z and x and sometime y depending to about 90 or so till the body os completly under the clothing, then grow it to the default 100% on the coords that I changed at about 15 frames, and leave it running for the full default 30 frames for it to settle a bit. You may also want to consider using morphs in teh calulations as well. I have been considering with tight clothing to grow the breasts into teh clothing as well this gives sometimes nice creases in teh clothing between the breasts.
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Furyofaseraph ( ) posted Mon, 03 January 2005 at 7:09 PM
Yeah, i was actually just thinkinga bout making a bunch of morphs that would basically de-push all the vertexes.
randym77 ( ) posted Mon, 03 January 2005 at 7:20 PM
Online Now!
I think the tutorial you are looking for at PoserFashion.net. At least, there's one there that uses scaling to fit a Stephanie dress to Judy.
Letterworks ( ) posted Tue, 04 January 2005 at 8:54 AM
Attached Link: http://www.philc.net/tutorialsIndex.htm
PhilC has a couple of tutorials on dynamic clothing at http://www.philc.net/tutorialsIndex.htm mike
svdl ( ) posted Tue, 04 January 2005 at 10:39 AM
Attached Link: http://svdlinden.xs4all.nl/poserstuff/downloads/usingdynamicclothing.zip
I've got a dynamic clothing tutorial in Word 2000 format. It isn't finished yet, but it does cover using scaling and morphs.
My gallery   My freestuff
xoconostle ( ) posted Tue, 04 January 2005 at 4:37 PM
I've downloaded your tute-in-progress and can't wait to read it, svdl. Thanks very much, and thank you for the great dynamic clothing freebies ... I learned to use the feature by playing around with your creations.
