Tue, Feb 4, 6:46 PM CST
Subject: special effects can any one help ?
DANBURNS4000 ( ) posted Mon, 03 January 2005 at 12:57 PM · edited Tue, 04 February 2025 at 12:46 AM
Hi this is my 1st post. can any one point me in the right way I am trying to make some speical efects like fire balls,lighting, and so forth can any 1 tell me the best way do this and what programes i might need. O and by the way i am useing poser 5
Message edited on: 01/03/2005 13:00
randym77 ( ) posted Mon, 03 January 2005 at 3:14 PM
Will this be for animation, or for still images?
sekhet ( ) posted Mon, 03 January 2005 at 5:46 PM
There was a program called Alma DV that came free on a computer arts magazine that does lighting fireballs sparks lasers and such both still and animation. You may be able to do a search and find a downloadable version.
xantor ( ) posted Mon, 03 January 2005 at 5:48 PM · edited Mon, 03 January 2005 at 5:51 PM
This is part of a halloween picture I did. The flames from the pumpkin are a flat picture with a transparency map to make it blend in with the scene.
Message edited on: 01/03/2005 17:51
maxxxmodelz ( ) posted Tue, 04 January 2005 at 12:34 AM
Attached Link: http://www.wondertouch.com/default.asp
Well, if you want to do some FX for animation, one great program you might want to look into is Particle Illusion. Basically, you render a poser scene, and them import it into this program to add FX, etc. to a scene in post. Most of them are highly impressive, and are being used by both amateurs and professionals alike. There's lots of presets for fire, smoke, lazers, and other such things.
DanR ( ) posted Tue, 04 January 2005 at 2:27 AM
Attached Link: http://fxhome.com/alamdv2/
Try AlamDV2 (demo available). Version 1 was given away on a cover disc - can't remember which one.
xantor ( ) posted Tue, 04 January 2005 at 10:43 AM
Windows xp is needed for alam dv, just so you know.
Terry Mitchell ( ) posted Tue, 04 January 2005 at 12:54 PM
I'll second the ParticleIllusion program. I also have the AlamDV program, but have yet to use it because PI does effects better and far easier IMHO. If you want to see PI put to good use, my Godzilla animation (it's posted at www.changestorm.com/godzilla) has loads of PI effects, explosions, fire, smoke, engine-heat exhaust, etc. that are pretty much right out of the box and took only a matter of minutes to do (each one). The posted animation doesn't appear in as good a quality as the original because of the extreme amount of compression that had to be used in order to get this large animation file down to moderately viewable formats, but it gives a good idea of what can be done witn PI even by a no-talent-to-speak-of person like me.
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
bobcat574 ( ) posted Tue, 04 January 2005 at 3:30 PM
I have to say Combustion 3. I've never used PI, but the two look extremely similar. The downside to Combustion, is the steep learning curve. But well worth the time to learn!
Terry Mitchell ( ) posted Tue, 04 January 2005 at 5:54 PM
Yeah, PI's effects program got integrated into Combustion, so it's benefits are all there plus the rest of Combustion's (which I do not have, but wish I did).
