Sat, Feb 15, 5:10 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: injection morphs
dukefama ( ) posted Wed, 12 January 2005 at 7:05 AM ยท edited Fri, 14 February 2025 at 6:28 PM
hi all, I was wondering if I insert injection morphs and i create my character and i remove it after i have created the necessary deformations. will it affect my chracter ? thanks
SWAMP ( ) posted Wed, 12 January 2005 at 8:32 AM
Yes...if you inject the morphs, spin the dials..then remove the morphs,your figure will revert back to default... Unless you "spawn morph target" for each body part you adjusted. After you have spawned morph targets for each body part (perhaps spawned a full body morph also),then you can remove the injected morphs and save your figure to the character library. An easier way would be to use "Injection Pose Builder" (Daz). Using that you would inj all the morphs, spin the dials to make you character, then save to the character library (without removing any morphs). Now open that cr2 in IPB and with a couple of clicks it will create a custom inj/rem pose file for you. What that new custom inj/rem file will do is inj only the morphs and their dial settings that you used to create the character. SWAMP
