Sat, Feb 15, 12:38 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: How do you put on clothes in Poser 5?
Alpha9992004 ( ) posted Wed, 12 January 2005 at 2:22 PM · edited Sat, 15 February 2025 at 12:07 AM
Hi, This is a question that i'm having a hard time on. This is what Faye74 told me, but i have Poser 5 & she only has Poser 4. She said it may be different. i still need to try this in Poser 5. Can anyone help me out? Is there anyone behind this screen............? Faye74 - In Poser 4: you click twice on your figure (v3, m3, Aiko... etc) then choose a piece of clothe out of your library. Click once on it, then click underneath on the button left to "apply" or to add the clothe to your figure. If the clothe does not match perfectly right away, choose the "parent" menu and click on "parent", then "name of your figure" which connect both with another, and thats it.
SamTherapy ( ) posted Wed, 12 January 2005 at 2:29 PM
Not quite. Double click on the first figure to load it into the scene, then for the clothes, click once to select, then the single check mark (tick) at the bottom to bring the clothing in. Next, go to the Figure menu and select "conform" and select Figure 1 or whatever your first figure is called. Clothes aren't parented, they are conformed. Just to confuse you though, there are some clothing props, such as hats and often some jewellery items which are perented. You'll find those in the Props library. Dynamic clothes are also props, but that's a whole nother can of worms.
SamTherapy ( ) posted Wed, 12 January 2005 at 2:31 PM
FYI, the same applies in P4, Pro Pack and P5. Except for dynamic clothes, which aren't available in P4 or Pro Pack.
xantor ( ) posted Wed, 12 January 2005 at 2:35 PM
You click on the doublecheckmark to bring in the clothes, clicking on the single one will replace the figure with the clothe item.
SamTherapy ( ) posted Wed, 12 January 2005 at 2:37 PM
Arse biscuits. My mistake. Sorry. note to self - Remember to engage brain before typing :)
