Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 2:22 am)
Hmm, I was just working on inputting the morph info by hand, from my own V2 to V3. The body morph works fine but I'll need to adjust the head morphs until I get a look alike. Trying to make a set of twins, one V2 and one V3. Thanks for the help.
casey42 - that is interesting that you say that because I assumed that the equivalent would work, i.e. for M2 body morphs on M3ToM2, but my assumption was wrong. I have since found out that M3ToM2 is still a unimesh character even though the body looked like M2's body. I am not sure whether the body of M3ToM2 or V3ToV2 accept any morphs at all. BluEcho - i was also thinking that it would be possible to do it by hand, but excessively tedious.
Well I did some experimenting in Poser with my morphs. I had to add all body morphs by hand and save the resulting V3 to a library. I then applied the saved V2 face file to V3 and got what I wanted. Then just saved to the figure libray and used Pose Inj to create my morph file for V3. Ghecked it and it works! Now to transfer my textures from V2 to V3 and make the MAT poses. Then my twins will be finished. Hard way to do it but it worked. :0)
Wow that is impressive :) Did you find that any of V2's morphs didn't exist in V3's morph packs, and did you find that even when they did they sometimes morphed differently ? Also when you applied the face pose, did you use the same technique of writing down the morphs before applying them to V3 ? Also, you could shortcut the texture transfer process with UTC though, couldn't you ?
The "barbarian" in V2 is "barbarian1" in V3. And there are one or two more that you kind of have to work out. When I first created SaBelle with V2 I saved her face to the Face folder as a fc2 file. Then I just used Mat Pose 3 to create her morph pose file. But when I tried to apply the entire morph tp V3 it didn't work. When I applied only the fc2 from V2 to V3 that worked so only the body was done by writing ion the morphs. Is UTC the Unversal Texture Converter? I don't have it yet but I guess it would work and be a lot easier. Right now I have to convert textures by hand...sigh. Well I need to get some sleep. Had trouble with acid reflex so haven't been to bed yet.
Hi, Can anyone tell me if it is possible to take a V2 morph set and use them on V3? Would Injection PoseBbuilder do it? I want to create a V3 twin of a V2 character morph. Thanks.
