Fri, Nov 15, 7:20 PM CST
Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
Subject: What's the newest version of Bryce these days?
peevee ( ) posted Thu, 13 January 2005 at 10:06 AM · edited Fri, 15 November 2024 at 4:54 PM
The last I know of bryce is that they released bryce 4. Is there a newer version available? the reason I ask this, is because I need a terain editing tool with export abilities to 3DS MAX(7) or poser(5). If you can help me please do... Thanks a lot Peevee
darkness_02 ( ) posted Thu, 13 January 2005 at 11:10 AM
hello Peevee.... Well I'm now to all this... but I'm using bryce 5... i don't believe that there a bryce 6 out yet... and I know u can inposrt 3DS files into bryce becuse i download a few starwars ships from http://scifi3d.theforce.net take a look everone when u have a min... they a pain at times.. but most work... or is it I'm too bad at all this that i tend to mass it up... but anyway I'm going on too muck... bryce 5 will let u inport most 3DS file.. Darkness
You imagination is your only limitation.
Check out Dark Design for freebies for your own artwork.
Sitemail Dark Design
dan whiteside ( ) posted Thu, 13 January 2005 at 12:29 PM · edited Thu, 13 January 2005 at 12:30 PM
Bryce 5.0.1 - that's Bryce 5 + the .1 update.
Bryce exports terrains to quite a few formats but .3DS and .OBJ should work with Max and I know that .OBJ works for Poser5.
Message edited on: 01/13/2005 12:30
mlofrano ( ) posted Fri, 14 January 2005 at 7:30 AM
Max will accept 3ds and I believe Bryce exports in that format. Bryce will certainly export obj, but depending on the version of max you are using, you may need an import plugin. The plugin is free (there are 2..one for exporting and one for importing). Just google it and you'll find it. Remember the plugins are version specific so get the one for the version of max you are running.
