Tue, Jan 28, 7:11 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: Library problem
SVicious ( ) posted Thu, 13 January 2005 at 5:23 PM ยท edited Tue, 28 January 2025 at 2:47 AM
i go to my pose library and when i click one of my menu items toward the bottom it loads the same menu item that loaded when i first went to the pose library why am i having this problem?
SVicious ( ) posted Thu, 13 January 2005 at 5:46 PM
Oh I use Poser 4 with pro pack
SamTherapy ( ) posted Thu, 13 January 2005 at 5:50 PM
You're having this problem because you have hit the 256 folder limit in P4 and Pro Pack. PBooost from the Marketplace is a very good solution to the problem.
ynsaen ( ) posted Thu, 13 January 2005 at 5:55 PM
SamTherapy is dead on. Outside of Pbooost, the only other otpion is to go in and start moving stuff around so you have less than 255 folders.
SVicious ( ) posted Thu, 13 January 2005 at 6:02 PM
thanks i was kind of figuring that was the problem
pakled ( ) posted Thu, 13 January 2005 at 6:12 PM
I think some things can be moved to the camera folders, but I'd wait for the experts to chime in...chime in, experts..;)
SamTherapy ( ) posted Thu, 13 January 2005 at 6:22 PM
Yup, you can move to Camera and Hands. You have to change the file extensions to CM2 and HD2 respectively. Also, one of the "Hands" will load the pose wrong but I can't remember if it's left or right. I tried that method before I got PBooost. Trust me, it's a royal pain in the arse.
Bobbie_Boucher ( ) posted Thu, 13 January 2005 at 8:13 PM
It's a royal pain in the arse to move all that stuff to the Cameras Library, and rename it all. Then those Libraries get full. I've also tried moving and deleting stuff, and made a mess of that. In the end, the only solution for me was to start over and use PBooost. But then I got Poser 5, and it's ability to use sub-directories, and external Runtimes. I'm much happier now.
