Tue, Feb 4, 12:56 PM CST
Forum Moderators: Staff
Subject: Need help with creating pose files for distribution
lferrand ( ) posted Mon, 17 January 2005 at 8:57 AM · edited Tue, 04 February 2025 at 9:44 AM
I developed a set of poses whih I would like to distribute on R'osity. Created them in P5, zipped, etc. - then I installed them in p4. Problems include (1) the .png images don't show up in the library, and (2) I get a number of "newer file version than expected" errors everytime I load a pose. The poses work fine, though.
Any help would be most appreciated.
Thanks,
Larry
(lferrand)
roxcat ( ) posted Mon, 17 January 2005 at 11:32 AM
Attached Link: http://www.senosoft.com/softp3doDownload.php
P4 uses rsr images instead of png. You can convert png to rsr with P3dO Explorer ( follow the link). And the newer version error is because in the pz2 files it probably says version 5. You can find this in the beginning if you take a look at the files in a text editor. You can change it to 4 and it should work fine: version { number 4 }
