Mon, Feb 17, 3:23 PM CST
Forum Moderators: RedPhantom
Subject: realistic teeth?
papyes ( ) posted Mon, 17 January 2005 at 11:07 PM ยท edited Tue, 11 February 2025 at 10:24 AM
i have so many good model so any expressions but the problem is the teeth never realistic...:( so perfect so white so..so if someone can tell me a good model for that or a link it will nice ;)thks a lot and don't forget life is a party;)
face_off ( ) posted Mon, 17 January 2005 at 11:19 PM
Teeth will always be difficult, since so much light bounces around inside them - they can be dull in the light and glow in the dark. Try plugging the texturemap into the ambient channel, and setting to .1. Then set diffuse to 0.9. Adding some red also helps - almost no one has while teeth - they are generally tinted red (from color bleeding from the face). To add the red, back the green and blue off to 200 in the diffuse and/or ambient colors. Turn off normal specular, and plug an Ansi spec node into the alt_specular plug. Set the ansi y to be double x (around 0.05?). Also, if you are using V3, use the teeth morphs to make them a little uneven.
Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
Plutom ( ) posted Tue, 18 January 2005 at 9:59 AM
Been wondering about that myself, going to give it a try-thanks Face_Off---Plutom
