Tue, Feb 18, 2:31 AM CST
Subject: Problems with loading a scene in Vue 5
Muggle6 ( ) posted Thu, 20 January 2005 at 2:46 AM ยท edited Sun, 16 February 2025 at 11:22 AM
I have just got Vue 5 and now I am experiencing quite a nerve wrecking problem. I want to load a scene previously edited and saved in Vue5 and after start loading (progress bar is incrementing), wosh... the scene is gone and I am back to where you are when you just started (no scene loaded). Then when I try it a second time (or sometimes a third time)it is workin: The scene is there! Is this a known problem? Does anyone has a solution? I am workin on a AMD 1400Mhz, with 1024 MB and GeForce MX400 plus WinXP SP1. I am also looking for a solution of these (Out of Memory)-crashes, but could find one in the history here. Again, any solutions? Thanks in advance!
deadhead ( ) posted Thu, 20 January 2005 at 4:37 AM
Yes, I have probably the same problem. Try this: When youre loading scene into Vue 5, dont click with mouse on other windows (even better, dont touch mouse LOL). I dont know why, but my Vue 5 hates when something happens during loading - for example Im loading scene, then suddenly shows pop up window with new email from my mail client and Vue stays blank...strange...
gaetan036 ( ) posted Thu, 20 January 2005 at 9:52 AM
For your memory try this---1-parametres-2-systeme-3-avanc4-performances,parametres avanc5-memoire virtuelle modifier,definir end change the number of your attribuate mory double you number exemple if you have 512(512>1024) me I have 1024 I put 3000,restarte your computer,dont have any problem after that
Muggle6 ( ) posted Fri, 21 January 2005 at 1:02 AM
Hey gaetan, I will try this. Thank you very much for your detailed explaination!!! Merci!!!
