Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 06 11:30 am)
Import the three pieces speratlely. Position them so they are in the correct places and so that moving one of the translation dials opens the drawer. Add the prop to the prop library. When prompted change the name to your prop name and select subset, check the boxes for the dresser and drawers. Poser saves the three components as one prop file. You can edit the pp2 file and rename the translation dial for the drawer or you can add code to the pp2 file that links a new dial in dresser to the translation dial of the drawer. ( There are a couple of tutorials on this - look for erc )
I modelled a couple props a dresser, and the drawers that go in it but its in 3 props (dresser, drawer, drawer) how to: 1. put the props into 1 (i export as .obj but they always come back 1 solid prop thus making the drawers unusable) 2. make a dial so i can open/close a drawer? i know i can change x/y/z to open/close and keep seperate but i wanted to have it 1 model, dial slides them open less thinking in long run ^_^ thanks
