Sat, Feb 8, 9:39 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Saving parameter key values to Pose File without delta influences
an0malaus ( ) posted Wed, 19 January 2005 at 7:23 PM · edited Sat, 08 February 2025 at 9:11 AM
I'm looking for a way to extract the morph target parameter key values in Python without the influence of JCM/ERC deltas. I'm trying to create a Full Body Morph pose file which includes the BODY actor valueParms and all BodyPart actor scales. I can create the file (I use scene.SaveLibraryPose() to create the PNG icon for me then overwrite the PZ2 file), but if I include the targetGeom parameters from the BodyPart actors, the morph effects are doubled (or worse in JCM cases) when I apply the pose file after resetting the figure morphs and pose. I can see, when I look at the file created, that the partial body morph parameters show the non-zero values imposed by the BODY valueParm full body morph rather than the zero key values shown for those parameters in Poser. I'm running on a Mac and have worked out how to get Python to display a proper Mac OS X file save dialog supporting filename entry and directory browsing as well as other Finder plug-ins. If anyone's interested in this bit, please let me know. Can anyone help with the parameter values? Ockham? Anyone?
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
ockham ( ) posted Thu, 20 January 2005 at 1:29 PM
I don't have any good ideas. Have you tried setting the FBM to zero, then calling scene.DrawAll() before reading the parms? Sometimes it takes a DrawAll() to get morphs where they really should be.
My python page
My ShareCG freebies
an0malaus ( ) posted Thu, 20 January 2005 at 7:05 PM
Thanks ockham, I was hoping I wouldn't have to go down that path, but it had occurred to me. The DrawAll() might help, though.
My ShareCG Stuff
mmogul ( ) posted Fri, 21 January 2005 at 11:05 AM
Or you can use a figure without the jcm/erc morphs... Morph Manager or CR2Editor can do the work, just delete the morphs that you don't want.
