Fri, Feb 14, 1:21 PM CST
Subject: Bryce Animation MOV questions.
drawbridgep ( ) posted Thu, 20 January 2005 at 2:53 PM · edited Thu, 13 February 2025 at 10:27 PM
I just created a short (13 frame) MOV file from Bryce and it's created the MOV file and a MOV#RES file. I can't run the MOV without the RES file being in the same directory. Says the MOV isn't a format that quicktime likes. It's quicktime 6.5.1 I just uploaded the MOV to the net and when I try to run it, I get a broken movie icon. WHY?! AND has anyone got any apps to convert a MOV or AVI to GIF? Not a thing I often do, so shareware would be perfect.
Phillip Drawbridge
Website
Facebook
drawbridgep ( ) posted Thu, 20 January 2005 at 3:02 PM
OK, I've worked out how to create an animated gif. I export from Bryce as a BMP range and use imageready. Should have realised that. Still not sure why the MOV doesn't work, but not so bothered now. Thanks
Phillip Drawbridge
Website
Facebook
TobinLam ( ) posted Thu, 20 January 2005 at 7:30 PM
I've always wondered about the mov#res files.
Zhann ( ) posted Thu, 20 January 2005 at 9:43 PM
You could output as an avi....
Bryce Forum Coordinator....
BOOMER ( ) posted Thu, 20 January 2005 at 9:51 PM
See DB, you should have just gone to Zhann The Forum Queen from the get go and you could have avoind all this. (and if Woody would have gone straight to the police, this would never have happened)
Because I like to blow $%&# up.
Don't fear the night.  Fear what hunts at night.
drawbridgep ( ) posted Thu, 20 January 2005 at 10:51 PM
Yeah, but the MOV was 200k and the AVI was 6 meg. (AlthoughI didn't play with compression settings, so maybe could have got it down) BUT the BMP worked great and only 200k gif.
Phillip Drawbridge
Website
Facebook
tjohn ( ) posted Thu, 20 January 2005 at 10:53 PM
You can also load a range of images as layers into Photoshop and export as gif. Takes a while, but it works.
drawbridgep ( ) posted Thu, 20 January 2005 at 10:57 PM
That's kinda what I did. But used image ready. You can open a folder as frames and it loads each BMP in the folder into a separate frame and then use save as GIF. Totally automatic.
Phillip Drawbridge
Website
Facebook
pogmahone ( ) posted Fri, 21 January 2005 at 1:27 AM
Attached Link: http://www.gfx2swf.com/
You can also use Flash Image Builder @ $24.95 to convert Bryce avi's to .swf
Zhann ( ) posted Fri, 21 January 2005 at 3:24 AM
Thanks for the link, yeah the 25sec avi I did came out to 50megs! I also found my version of PSP has an animation lab included, handy....
Quest ( ) posted Fri, 21 January 2005 at 4:31 PM
Attached Link: http://www.ulead.com/ga/runme.htm
Ulead Gif Animator converts AVI, FLC, FLI, FIX, GIF, MOV, QF, MPG, MPEG-2, MPV, MP2 into an animated GIF. 10.3Mb. 15 day Trial version is fully functional.
pogmahone ( ) posted Sat, 22 January 2005 at 3:24 AM
hmnnnnn...have to say that those gif animations look more useful than swf. I got locked into thinking along swf lines because of using Atmosphere - it can use swfs as texture. But for uploading to webpages gif definitely looks more useful.
