Sun, Nov 24, 10:43 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Dynamically Lengthen Hair?
danielsangeo ( ) posted Thu, 20 January 2005 at 1:12 PM · edited Sat, 27 July 2024 at 12:10 AM
I am revisiting an old thread from May 2004. My apologies. I attempted to post in that thread but got no response. You can view the thread in question here:
http://www.renderosity.com/messages.ez?Form.ShowMessage=1784146
The idea behind said Poser Python script is to lengthen dynamically grown hair over the course of an animation. Unfortunately, since I know jack about Python scripting itself, I'm totally clueless about the script.
Apparently, I'm supposed to set a variable in the script that tells the script how many frames the animation is, but I keep getting the "invalid syntax" error and I don't know where to place this frame number variable.
What am I doing wrong? Or should I be even trying to venture into Poser Python scripting without any Python background at all?
Thank you!
tromnek ( ) posted Fri, 21 January 2005 at 8:46 PM
A quick look at the script and your reported error tells me that you need to put a blank line following: print "Something wrong..." that should solve the SyntaxError.
danielsangeo ( ) posted Sat, 22 January 2005 at 7:48 AM
Thank you, thank you, thank you!
That was exactly the problem! You're a life saver, tromnek!
And thank you, NRuddock for originally posting the script! You two have just increased my Poser usability a thousandfold!
