Sat, Feb 8, 9:35 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Morph Injection without pre-existing PBMCC_ carrier query
an0malaus ( ) posted Wed, 19 January 2005 at 7:08 PM · edited Sat, 01 February 2025 at 7:57 PM
I'm currently packaging up some knee and buttock bend morphs which allow extreme bends without (visible) mesh overlap. I've basically run out of pre-existing PBMCC_ channels and I need to add 7 new morph/control channels to the thigh (with lesser numbers on the buttock and shin). If I can avoid using these, the package will remain compatible with other morph injectors. I seem to remember reading that someone had discovered a way to inject morphs into V3 without using or overwriting the pre-existing PBMCC_01 to PBMCC_30 channels. Can anyone point me to that information. [Originally posted in the Poser and Poser Technical Forums, but no-one's biting there. Is this so hard? Am I whistling through my chapeau?]
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
an0malaus ( ) posted Thu, 20 January 2005 at 9:01 PM
Ah hah! I think I've found what I was looking for... http://www.renderosity.com/messages.ez?Form.ShowMessage=1474180 Describes how to create a morph carrier CR2 file which readScripts in the original character CR2. Unfortunately I'm off on vacation for the next 2 weeks, so I won't have time to play or respond before I come back, boo hoo ;-( Sorry this was a bit OT for Python, but if anyone knew, I thought it would be here I got a response.
My ShareCG Stuff
ockham ( ) posted Sat, 22 January 2005 at 12:29 PM
Thanks for posting the search result anyway. Searching Rendo is so difficult that it's always nice to get a useful result recorded in the open!
My python page
My ShareCG freebies
