Wed, Dec 25, 12:40 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: HOW? simple render with clean black lines around objects
Nate ( ) posted Mon, 24 January 2005 at 2:50 PM · edited Wed, 25 December 2024 at 12:33 AM
I have a need to render some simple objects, and because of size and printing limitations, I must outline each object with a clean black thin line.
I have experimented to exhaustion with Non-Photorealistic styles in Carrara 3. I get all sort of stuff other than what I need.... Diffusion layers with all sort of odd paint patterns (messy, dirty) when what I want is just the plain simple flat colors from the objects (yes, I selected use object color, but it still goes artsy and does cute swishes of shades and colors).
The other frustration is that the black lines I get either go beyond the edges of the objects or stop short of the edges. Turning on object clipping is of no help.
The manual is of no help in figuring this out... and I have found nothing on line..
Anyone know how to accomplish this rather simple task?
(I tried vector style, but I don't want it that simple either)
thanks loads!!
Nate.
On-line portfolio / Making figurines in China / Gallery  / Video Demos
mdesmarais ( ) posted Mon, 24 January 2005 at 2:56 PM
Did you try Toon? DCG has a new-ish plugin if toon doesn't quite cut it. http://www.digitalcarversguild.com/ Markd
Hoofdcommissaris ( ) posted Mon, 24 January 2005 at 3:00 PM
There is also the Toon! render... (you can choose that somewhere in the render room or in the 'scene' settings...) I do not have full memory of how that worked in C3 (I did not use it recently), but it sounds like something useful. There must be documentation on that somewhere (maybe even the manual). The best would be the VectorStyle plug-in from the Eovia site. But that costs money. It even exports Flash and illustrator, it does not get any cleaner than that!
Hoofdcommissaris ( ) posted Mon, 24 January 2005 at 3:16 PM
(I did not read Markd's answer when typing mine, there are similarities)
Nate ( ) posted Mon, 24 January 2005 at 4:03 PM
Thanks...
As I said in my first message, vector style doesn't cut it as it needs to simplify things too much... just one light source, etc.
Carrara 3 has no toon setup... that apparently went south with version 2. It has the NPR (aka Non PhotoRealistic) setting which, as I described is what I'm trying to work out.
will check the dcg for what's new...
Hoofdcommissaris ( ) posted Mon, 24 January 2005 at 4:47 PM
Wait. I will unstuff my Cararra 3 copy. I KNOW it is somewhere in there...
mmoir ( ) posted Mon, 24 January 2005 at 4:47 PM
Carrara version 3 still has Toon , I think it is "ctrl+shift+t" then look in the properties tray , then locate the "filters" tab. It should be in there ,also render your image larger to get cleaner toon lines. Good luck Mike
falconperigot ( ) posted Mon, 24 January 2005 at 4:53 PM · edited Mon, 24 January 2005 at 4:56 PM
Toon is available in C3. In the Assembly Room, click the Scene tab in the Properties Tray and look under filters. If you click Edit there are various options for line thickness, Toon degree etc. This pic was done in C4 but you should be able to get the same effect in C3.
Toon Pro, new from DCG , is I think only available for C4.
Message edited on: 01/24/2005 16:56
Hoofdcommissaris ( ) posted Mon, 24 January 2005 at 4:56 PM
Instances - click on 'Scene' - choos Toon! Part III It will kick in as after-render filter. It is rather fast, so rendering at multiples of your end-size is easy and will give you sharper lines. (now I will stuff C3 again, it pays to have it around...)
falconperigot ( ) posted Mon, 24 January 2005 at 5:06 PM · edited Mon, 24 January 2005 at 5:08 PM
Alternatively, if you want to try the Non-Photorealistic renderer again try these settings: Make sure only Diffuse and Outline are checked. Set the Max and Minimum Brush size to 3. Check Object Clipping and Use Object Color. And select the Disk brush shape from the Geometric set (click on the brush shape to get the options).
The top image is using just the Outline. HTH,
Mark
Message edited on: 01/24/2005 17:08
Nate ( ) posted Mon, 24 January 2005 at 6:45 PM
Ooops... my bad....
I expected the Toon render to be in the render room... how silly of me... of course the toon render would not be in the render "room" but in the effects closet in the properties room... guess I need a map to get around in all the rooms...
Thanks --- I will try all of these and see what I can come up with....
regards,
Nate.
ShawnDriscoll ( ) posted Mon, 24 January 2005 at 7:10 PM · edited Mon, 24 January 2005 at 7:15 PM
Toon! III (I think it's called) does a fair job in Carrara Studio 3. The new DCG plug-in called Toon! Pro, for Carrara 4, does a fantastic outline function on Carrara's already fantastic renders. See my gallery for Toon! Pro and Wireframe Pro (origami) samples.
Message edited on: 01/24/2005 19:15
Kixum ( ) posted Mon, 24 January 2005 at 7:30 PM
The toon option can generate great results! -Kix
-Kix
Nate ( ) posted Tue, 25 January 2005 at 2:37 AM
Kixum... that really kix! Guess more experimentation is needed. Maybe even have to upgrade to C4.
First pix shown above is using exact settings that falconperigot recommended... not working too well.
Second pix (next post) is toon 3 setup - it is closer to what I was hoping to get.
Really appreciate your help!
Nate ( ) posted Tue, 25 January 2005 at 2:40 AM
Here's the toon 3 setup - closer....
ShawnDriscoll ( ) posted Tue, 25 January 2005 at 2:42 AM · edited Tue, 25 January 2005 at 2:49 AM
Outlining with 100% is for true non-photorealistic images. Change the outline thickness to around 25-30% and the outline length to around 70-75% to get regular outlining in non-photorealistic renders. Also, cut down on the diffuse percentages as well to lessen the smudging.
I'm not sure if the Toon plug-ins will draw all edges.
Message edited on: 01/25/2005 02:49
Nate ( ) posted Tue, 25 January 2005 at 3:28 AM
Shonner...
I have been to and bookmarked your gallery.
What you are doing there is precisely what I am looking for. It seems I'm going to need to update to C4 and pick up a few more plugs from Digital Carver.
Thanks for the pointers. Truly amazing.
Will look to see if you have posted any tutorials also.
(Have you?)
Nate.
bluetone ( ) posted Tue, 25 January 2005 at 10:01 AM
While I haven't played with the Toon options much... it seems to have a 'Highlight Edge' parameter that you have set to 0. Maybe by sliding it up to the same as the 'Shadow Edge' and 'Object Edge' you would get the look that you are looking for. Hope this helps! :D
Kixum ( ) posted Tue, 25 January 2005 at 6:28 PM
Set your edge in degrees lower. Then those 90's should ALWAYS show up. -Kix
-Kix
