Attached Link: http://www.videohelp.com/dvd
Different standards. The link has probably everything you need to know.Thanks for the link. It really doesn't get into the technical differences other than -R is slightly more compatible than +R. And that -R holds slightly more data. But that +R is the only Dual layered technology so far. I wonder if it something like a -R disc is actually full and the laser creates holes (ie: subtracts space) to make 1s & 0s. Whereas a +R disc is completely empty and uses the laser to make bubbles (ie adds space) that read as 1s & 0s. Which means a -/+R DVD writer can both make and subtract space. Which is probably why RW writers are almost always -/+RW. I'm probably way off on this theory.
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
Here's the jist of that second link. Sounds like -R is the pits (pun intended). Although the arguments presented in this document might look like technical details to most readers, disc format is what defines the limits of what drives can do with a given medium, both in terms of performances and features. Therefore, the technical advantages of the DVD+R(W) format will with time turn into faster, more powerful and more reliable drives for end users. This is already the case today, and the gap will continue to increase as DVD+R(W) drives will exploit more and more of the advantages of the + format. However, as history showed, the best ideas are not guaranteed to win on technology markets, and only time will tell which format becomes the new standard. But as long as manufacturers continue to produce hardware that is compatible with both standards the -R vs +R battle seems to be of minor relevance. Certainly not battle of Beta vs VHS of the early 80s. Beta was clearly the better standard.
<br />
Freestuff</a>
Just something else to consider bandolin; If you ever intend to burn video to DVD, and use it in your set-top DVD player, I'd suggest going for +R/RW Obviously though, dual/all format drives are real cheap now, so I reckon a "dual" or "all" format drive would be the way to go.
The wait can be horrific, but the outcome can be worse - pumeco 2006
On a practical note, if you want your dvds to work on your bog-standard home dvd player (attached to your tv), the format you want is DVD-R. However, you can get a machine that will write + & - .
It's just my personal experience...but the DVD-R's have sucked booty maximus in my PC Burner (made many a drink coaster) and don't work at all in my living room/component DVD Recorder. I'm sure it all has to do with what brand name devices you are using, but I will stick with my Memorex DVD+R's. With them, I haven't had one single problem. AgentSmith
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
I'm thinking of buying a DVD writer. What's the deal between -R and +R. I know they're different standards, but technically anyone know what that difference is?
