Vue F.A.Q (Last Updated: 2024 Oct 17 8:34 am)
I think all plants look bad in Vue, except the rubber plant, stangely,and it has to do with the shading ( reducing ambiant lighting gives better results), and you need to work on the size of the procedurals used for trunks (scaling them differently), be it colour or bump. Give your leaves a little blurry reflections (increases render time). you can also change the image map if you have any images of the leaves you want ( must have an alpha channel), and it doesn't always work ( few chances it's gonna work with the palmtree, mut may work with simpler plants). That's all I could find to have better Vue plants (apart from modelling my plants in XFrog, that is!), and it's true they work better in the background. PS:These advice work for Vue5.
Before you convince everyone that all palms have tapering trunks get a good book on palms like Palms Throughout The World by David L. Jones. And you will find that many don't have much taper to the trunk. Some such as certain Phoenix palms actually get biger toward the top. I have palms in my yard that look much like the Vue palms. We don't know what palm imspired their model. And yes some palms are like vines no bigger than your finger, The trunks of these are used as rattan and are commonly 50 to 100 meters long. There is lots of room for good modelers in this area and I think all of us would like more kinds. Glenn in Puna, Hawaii
There is a huge downside to xfrog trees though, yes, they look really really nice, but they have really high poly counts, I know that you can reduce the poly count but I've never seen what happens when you do that (quality wise). They also add quite a bit to render times unfortunately, so definately use them sparingly when you do use them.
I use Xfrog trees, for up close type things...you can always make then into alphas for the background :) I've also saved all my Xfrog models as .vobs...saves time ;) You could also find a texture on the web for the Vue palm trunk/bark & replace it in the materials summary :) I bought a book on trees for this exact purpose replacing barks & leaves.
Ggrace, it wasn't my intent to generalize ALL palms. I am fully aware of the many thousands of varieties. I believe though that Vue intended this to be your average coconut palm, which as far as I know have significantly thicker bases. In searching the web I couldn't find any that looked like the Vue palms altogether. The top portions, yes, but not the trunks. And then you have the Cycads with short stocky trunks, and the ones that you described that are thicker at the top. But I have never seen any that resemble the ones in Vue.
Attached Link: http://www.mayang.com/textures/Nature/html/Plants%20and%20Derived%20Materials/Wood/Bark/
Here you go....this guy has some other fantastic textures, on his site...well worth checking out :) FYI - In google I typed in palm bark, then clicked on images...quite a few there :) Hope this helps.Yay! More textures to play with! Thanks for the link dlk, not many palm / tropical trees up here in Washington! I'll have to try saving them over as vob and see if that helps (for the xfrog plants). Another suggestion for getting a different trunk, grab a modeling program and do a quick model of a trunk, then make the vue palms trunk transparent and stick the leaves on the top of your newly modeled trunk and apply textures accordingly. There are plenty of free 3d programs (or earlier versions available on 3dworld cd's) out there that shouldn't have any problems modeling something like that. Not quite as easy as pushing the veggie button in Vue but at this point I wouldn't count on E-on updating their plant collection (considering most of those plants have been around since version 2 of Vue, maybe earlier)
I know this thread is a bit old, but, I bought the Botanica add-on for Vue 5 Esprit, and I'm pretty dissapointed. The options are very limited, depending on groups available within a plant. I was expecting to be able to manipulate plants like you can manipulate terrain, bit not so. So, in short, I can't make the kind of palm tree I want out of the types inherent to Vue 5 Esprit. Can't adjust the taper of the trunk. If I chage the trunk diameter the whole trunk changes, making it even uglier. The claim that you can create whole new species from existing ones is a stretch, at best.
Attached Link: http://dreamp.club.fr/plante1.htm
Sure the plant editor is pretty basic and disapointing, you cannot change any geometry. But you can change the polygon count which can make a huge difference, and create new species, but based on existing ones only. But some have made pretty good use of it. Check the link.I know, but a maple with really big leaves and a bit droopier is still a maple. I would loke to be able to edit the trunk and leaf geonemtry, add or subtract points to a leaf, serrate the edges, make them thin like needles, but it's nothing likt that. In all the plants you display on that link I can tell what they came from. I wouldn't call them new species, new variants, new cultivars, maybe.
Is it me or are the palm trees in Vue simply horrendous?? The trunks are the problem. They're WAY too thin throughout. Real palms are much thicker at the base and taper up. These are just no good in anything but a very distant shot. Would be nice if they also had a variety of palms as well. Jeff
