Thu, Jan 9, 1:34 PM CST
Subject: Help
froggatt ( ) posted Wed, 03 January 2001 at 2:19 PM ยท edited Thu, 15 August 2024 at 7:09 AM
HI MIGHT SEEM A SILY ? WHOT IS THE BEST PROG TO USE SO I CAN CREAT MORPH TARGETS......I HAVE, 3D STUDIO,CARRARA,TURESPACE FORMZ,CINEMA 4D ETC..... THANKS....TIM
PhilC ( ) posted Wed, 03 January 2001 at 2:53 PM
Truespace works if you convert from COB to OBJ via 3D Explorer. (ignore the triangulation it does not affect the morph). philc_agatha_white_on_black.jpg
JeffH ( ) posted Wed, 03 January 2001 at 2:55 PM
The best one is whatever works for you...try Carrara or 3DS.
froggatt ( ) posted Wed, 03 January 2001 at 3:45 PM
i keep getting this message.....TARGET GEOMETRY HAS WRONG NUMBER OF VERTICES......what am i doing wrong ????? This is when i use Carrara
Ghostofmacbeth ( ) posted Wed, 03 January 2001 at 3:53 PM
With Ray Dream I know that you can't mess with the size. Since that is the predecessor to Carrara it might be the same thing. Not sure what else. I know you have to mess with the base mesh and not an export from poser. Hope that helps. Later
JeffH ( ) posted Wed, 03 January 2001 at 5:07 PM
Attached Link: http://www.atless.net/~arcady/3D/carrara_morphs.html
If you're getting the "Wrong Number of Vertices" error it means that you're using the wrong part for that figure. The head does not include the eyes when doing Morph Targets. http://www.atless.net/~arcady/3D/carrara_morphs.html
