Mon, Feb 3, 3:10 AM CST
Subject: Mover 4 import animation problems
JoeBlack ( ) posted Sun, 30 January 2005 at 7:35 AM ยท edited Mon, 29 July 2024 at 3:25 AM
I'm using Vue 4.10, and Mover 4. I create an animation in Poser 4 of 60 frames. I save as PZ3 file. I then import the PZ3 file into Vue, and select "Import entire Poser animation". However, once it has loaded, Vue has only sees 2 keyframes, where there whould be 60! On the timeline I press "next keyframe" and it jumps straight to the end of the animation, ignoring what should be in between.It doesn't matter how many keyframes I make in Poser, Vue always refuses to see or recognise them.
Does this sound like a bug, or should I just update? I hate updating because often the patches produce more problems on my machine than they're worth, hence why I'm still using 4.1.
Phoul ( ) posted Sun, 30 January 2005 at 7:46 AM
Not sure it is the solution. But try. Could be. So...
Create same frame rate in a vue animation (a blank one) than you poser animation, before importation. For instance if in poser it is 25 frames per seconds, create same at 25 fps in Vue.
krimpr ( ) posted Sun, 30 January 2005 at 7:59 AM
I maybe don't understand your question, but I don't think Vue will see any keyframes in your pz3. Only Poser will see them and you have to make your changes there.
Dale B ( ) posted Sun, 30 January 2005 at 9:51 AM
Exactly. A Poser animation plays within Vue in a self contained fashion; the only keyframe controls in Vue would be things like if you keyed a texture change. Or shifted the actual Poser file in the Vue worldspace.
