Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
Before you saved them, did they have an external object file? That is...to make the smart prop, did you import an object, parent it, then save it to the library? I'm willing to bet you need to edit the file in a text editor (or is there a handy utility for this yet?); to change the section that reads; { geomCustom numbVerts 4422 numberTVerts 4483 ----- 0.001 -0.002 -4.456 0.001 -0.002 -4.033 ----- } and replace it with : FigureResFile:Runtime:Geometries:a_folder:a_prop.obj Go find a prop with an external geometry file (DAZ requires their merchants to make them this way), and compare the changes in the file. It's simpler than I make it out to be.
Saving as a smartprop certainly shouldn't make such a difference. The external geometry is a little bit of a red-herring, at least for one copy of the prop. But if you want two copies, one for each hand, external geometry pays off big. All the versions of the prop have their own .pp2 with a single geometry file.
...and don't say, "genetics." I'm creating a series of props. When I save them unparented, they are a managable .25 meg or so. When I save them parented to M3's right hand they suddenly megabloat to a freakish 15 meg! Not good, since the limit for the RMP is 25 meg... Aside from putting them on a diet and providing plenty of excercise, how do I slim down my smart props? Many thanks, Kukri
