Blender F.A.Q (Last Updated: 2025 Feb 09 8:29 pm)
i got an error runing it on my windows comp????
for
some free stuff i made
and
for almost daily fotos
did anybody else try it ? maybe its just a typo?
for
and
no didnt you try it yourself????plz post only working stuff.
for
and
This is unlikely to work, since python relies on correct indenting (which is lost in these forum threads).
Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
Attached Link: http://www.elysiun.com/forum/viewtopic.php?t=30101&highlight=render
A nice script if you want to read more about it. The attached link goes to some images. Pretty slick I think. And shows the power of scripting. Definetly think every program should have scripting capabilities. by shteeve from Elysiun: new to version 0.2: -restructured the way vertex data is managed... should give a large speed improvement -now operates on the currently selected mesh so you don't have to change any code (although it'll crash if you've got nothing selected) -provided a simple gui Blender import * import math scale = 0.01 falloff = 0.5 object = Object.GetSelected() mesh = object[0].getData() faces = mesh.faces vList = mesh.verts vInf = range(len(vList)) def event(evt, val): if evt == Draw.ESCKEY: Draw.Exit() return def button_event(evt): global scale, falloff if evt == 1: scale = B1.val elif evt == 2: falloff = B2.val elif evt == 3: time1 = sys.time() print "Gathering mesh data..." for faceNum in range(len(faces)): face = faces[faceNum] verts = face.v cols = face.col for vertNum in range(len(verts)): vert = verts[vertNum] col = cols[vertNum] for v in range(len(vList)): if vert.co[0] == vList[v].co[0] and vert.co[1] == vList[v].co[1] and vert.co[2] == vList[v].co[2]: if vInf[v] == v: vInf[v] = [[faceNum, vertNum]], col else: vInf[v][0].append([faceNum, vertNum]) if vInf[v][1].r < col.r: vInf[v][1].r = col.r if vInf[v][1].g < col.g: vInf[v][1].g = col.g if vInf[v][1].b < col.b: vInf[v][1].b = col.b print "Calculating..." factor = [] for x1 in range(len(vList)): v1 = vList[x1].co factor.append([]) for x2 in range(x1 + 1, len(vList)): v2 = vList[x2].co dist = pow(pow(v1[0]-v2[0], 2) + pow(v1[1]-v2[1], 2) + pow(v1[2]-v2[2], 2), falloff) if dist > 0: factor[x1].append(scale / dist) else: factor[x1].append(0) sss = [] for x1 in range(len(vList)): c1 = vInf[x1][1] sss.append(NMesh.Col(c1.r, c1.g, c1.b, c1.a)) for x2 in range(x1): c2 = vInf[x2][1] sss[x1].r = sss[x1].r + int(factor[x2][x1 - x2 - 1] * c2.r) sss[x1].g = sss[x1].g + int(factor[x2][x1 - x2 - 1] * c2.g) sss[x1].b = sss[x1].b + int(factor[x2][x1 - x2 - 1] * c2.b) for x2 in range(x1 + 1, len(vList)): c2 = vInf[x2][1] sss[x1].r = sss[x1].r + int(factor[x1][x2 - x1 - 1] * c2.r) sss[x1].g = sss[x1].g + int(factor[x1][x2 - x1 - 1] * c2.g) sss[x1].b = sss[x1].b + int(factor[x1][x2 - x1 - 1] * c2.b) for ref in range(len(vInf[x1][0])): mesh.faces[vInf[x1][0][ref][0]].col[vInf[x1][0][ref][1]] = sss[x1] mesh.update() Redraw() time2 = sys.time() print "calculation time: ", time2 - time1 def gui(): global B1, B2, B3 BGL.glClearColor(0.7, 0.7, 0.7, 1) BGL.glClear(BGL.GL_COLOR_BUFFER_BIT) BGL.glColor3f(0.75, 0.75, 0.75) BGL.glRecti(5, 5, 195, 55) BGL.glRecti(5, 60, 195, 115) BGL.glColor3f(0.65, 0.65, 0.65) BGL.glRecti(5, 115, 195, 135) BGL.glColor3f(1,1,1) BGL.glRasterPos2i(10, 122) Draw.Text("Effect Options") BGL.glRasterPos2i(10, 150) Draw.Text("SSS by shteeve") B1 = Draw.Number("Scale: ", 1, 10, 90, 180, 20, scale, 0.001, 1.0, "Intensity of effect (usually small numbers)") B2 = Draw.Number("Falloff: ", 2, 10, 65, 180, 20, falloff, 0.001, 1.0, "Falloff of effect") B3 = Draw.PushButton("Calculate!", 3, 10, 10, 180, 40, "Calculates effect.") Draw.Register(gui, event, button_event)
