Fri, Jan 10, 2:12 PM CST
Forum Moderators: Staff
Subject: Problems with saving poses
SergeantJack ( ) posted Thu, 04 January 2001 at 10:11 PM · edited Tue, 26 November 2024 at 4:58 PM
Can anybody tell me why the x,y,and z-trans information on a character will not save when I save poses? I know it's possible to save that information in a pose, because I downloaded some that do. Help!
doozy ( ) posted Fri, 05 January 2001 at 5:11 AM
Did you trans the "hip" or the "body"? I would try it each way and see if one works.
bloodsong ( ) posted Fri, 05 January 2001 at 11:16 AM
heyas; i just noticed today that the body rotations don't seem to save. i guess in case you need two people standing around the same, but facing different directions. use the hip to turn the figure around, if orientation is important to your pose. :)
SergeantJack ( ) posted Sun, 07 January 2001 at 6:44 AM
I transed the bodies. In some cases, I used all three trans morphs (x,y,z). Can anybody give me some help? I've made dozens of really great poses, but I can't post them anywhere because of this problem.
bloodsong ( ) posted Sun, 07 January 2001 at 11:15 AM
heyas; why is it a problem? people can apply the pose then move the figure wherever they need it. unless, of course, the poses all interact with each other.... if you still have the pz3 file that saves the body trans's, then go add the body trans values to the hip trans values and re-save the pose. that should work, i think. (ps: technically, a trans dial isn't a morph :) )
