i have 3dsmax 3.0 and i import her file from runtime/geomities and it works fine for me, if your using the objtomax import plug just set it as follows import options: multiple Geometry options check all besides unify and dont check anyting else aslo if you export an obj from poser you should only select the very first option, cant rember the name something like name all parts? and select the last option, as one world morph should work if your doing that...
Hey does anyone know a solid good way to impotr correctly Zygote's Vicky into 3DSMAX? When I import her I have the hall figure as one mesh!!!!! I dont't have the same problems with Poser default characters! I allready use the latest plugins for 3dsmax v3.1 from Habware! I would prefer a direct answer via this forum and not a link to another page if possible (I've read too many of them!!!!!!!) Thanks!!!!!
