Wed, Nov 20, 12:17 AM CST
Subject: exchange clothing between Laura and sp3
LanceB ( ) posted Sat, 05 February 2005 at 6:09 AM · edited Sun, 17 November 2024 at 10:26 PM
I see a clothing item that is advertised to fit both Laura and sp3. Are young teens and sp3 close enough in size to share the same clothing?
randym77 ( ) posted Sat, 05 February 2005 at 9:37 AM
Not really, though I suppose it depends on what it is.
Which clothing item is it?
There may be two versions in the package. Or there may be "fit morphs." The clothing is designed to fit SP3, but has a "fit to Laura" morph. Or vice-versa.
steveshanks ( ) posted Sat, 05 February 2005 at 11:27 AM
I'd guess you get 2 items of clothing as once the SP3 set is made its reasonably easy to convert the mesh.......Steve
LanceB ( ) posted Sat, 05 February 2005 at 12:00 PM
On rechecking the item, "winter wonders", I see that it fits Laura and SP, not SP3. That makes more sense since Laura and SP are both the millenium mesh and not unimesh. Thanks
Natolii ( ) posted Sat, 05 February 2005 at 12:23 PM · edited Sat, 05 February 2005 at 12:24 PM
Lance,
SP and SP3 are the same figure. They are both common identifiers for the Stephanie Petite model which is a Millenium 3 figure.
Netherworks offered 2 versions of this outfit. One for Laura and one for SP(3). I currently own both sets. Hope this helps.
Message edited on: 02/05/2005 12:24
Netherworks ( ) posted Sun, 06 February 2005 at 6:19 AM
Yes, they are separate products - one for Stephanie Petite and one for Laura. The outfits share the same UV Mapping so any textures for this set will fit both products. The morphs were done individually and separately for both versions and will work with many of the DAZ morphs plus the morph packs I released for those two figures. Hope this helps - it's late and I'm about to drift off :D
LanceB ( ) posted Sun, 06 February 2005 at 9:38 AM
Thanks Netherworks. So if they are separate products I should be able to buy the SP3 outfit, but I can only find the Laura outfit on renderosity-where can I get the SP3 outfit?
LanceB ( ) posted Sun, 06 February 2005 at 9:45 AM
Netherworks, I just found your website where I can buy the outfit for SP3. Thanks
