Sat, Jan 11, 4:07 AM CST
Subject: Why is the volumetric fog black :(.
dlk30341 ( ) posted Sat, 05 February 2005 at 6:59 PM · edited Thu, 21 November 2024 at 4:19 AM
I needed to add some fog to my pic & it was black instead of white :(. And yes the color was set to white. I tried messing with the settings to no avail. I posted over at E-ON as well in case this is a bug. Using V5P/latest update TIA
spedler ( ) posted Sun, 06 February 2005 at 7:53 AM
Hmm, I can't reproduce this. Using V5, latest official update, and the default atmosphere which is then switched to volumetric. If I add white fog, I get white fog. Was your fog black on render as well as in preview?
Steve
Phoul ( ) posted Sun, 06 February 2005 at 8:11 AM
What % has your fog(s). what colors?... And so on.
That is not a soft bug, of course!
dlk30341 ( ) posted Sun, 06 February 2005 at 8:46 AM
Here are 2 screenshots.....
dlk30341 ( ) posted Sun, 06 February 2005 at 8:47 AM
another, and yes it renders black.
Phoul ( ) posted Sun, 06 February 2005 at 8:52 AM
Ah ok. On an object.... Well it is not a bug. I confirm.
Play (learn) lighting and effect tab indeed (i.e. luminous). Good luck.
dlk30341 ( ) posted Sun, 06 February 2005 at 9:06 AM
Thank You Phoul!...I've never seen this before...my fog always used to come out white.... Off to learn/play ;).
Phoul ( ) posted Sun, 06 February 2005 at 9:12 AM
You are welcome. :o)
spedler ( ) posted Sun, 06 February 2005 at 9:27 AM
Ah, I misunderstood. I thought you meant the fog in the volumetric atmosphere. I guess that what you have is indeed working as intended.
Steve
dlk30341 ( ) posted Sun, 06 February 2005 at 9:33 AM · edited Sun, 06 February 2005 at 9:39 AM
Well, I messed with lighting...luminous & all the other settings to no avail.
At this point it must be the mats themselves...These are from Vue4.....I believe these are from Boos-addons here in store(off to check to be sure)...ALL of them are not working..I have about 10-15. These include fire/neon/dust etc.
Going to redownload & see if this helps. COlor me stupid with all this....so mind boggling....need more coffee LOL Edited to say these are NOT Boos addons...off to research where I got these from - sigh -
Message edited on: 02/06/2005 09:39
dlk30341 ( ) posted Sun, 06 February 2005 at 11:00 AM
It's in the node editor...how V5 is reading the mat thru the nodes...I copied settings from a "smoke" mat that WAS working. So...all is well. Whew...that was heavy LOL
