Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 01 3:49 pm)
Do the files it's asking you to find have the extension ".BUM" ?
If so your using files that have been setup for P4.
Check the ReadMe that comes with whatever item your trying to load, and it should tell you which ".JPG" file would need to be converted (by P4) and use that instead.
Newer items tend to come with sets of MAT poses for P4, PP and / or P5, so if the items you have only have ones for P4, the only permenant fix is to change the extension in the file in question with a text editor.
Many times, the texture paths in the MAT files are not correct and so Poser goes on the hunt for them. You may want to take a look at Hogwarden's "Correct Reference" program which checks your CR2 and PZ2 files and corrects the texture location. There is a free version here: http://www.hogsoft.com/ and a more substantial 'Pro' version here: http://market.renderosity.com/softgood.ez?ViewSoftgood=27516 Personally, I wouldn't be without this program but do be aware that the free version has a few minor quirks when correcting textures: If searching for (eg) a texture called 'red.jpg', CR will assign the first one it finds alphabetically in your textures folder even if it's not the correct one for that specific MAT. The pro version alerts you when it finds 2 or more textures with identical names which is helpful. (The pro version also checks and correct Geometry files/locations) As long as you're aware of this and keep an eye on the dialog report box when CR is running you should be ok. Also, don't try and change too many folders at once or you'll lose track of what's happening!
Hi all... When I want to add clothes to the figure, it usually asks me where to find a file (texture) and I have to search for it and usually can't find it. I am using store bought items and they are extracted to their proper folders and I would think that the files included would point to where the neccassary files would be. Any way to fix this? It happens 50% of the time. thanks! Jeff
