Tue, Feb 25, 7:12 PM CST
Vue F.A.Q (Last Updated: 2025 Feb 23 3:59 pm)
Subject: half underwater scenes
palagas ( ) posted Mon, 14 February 2005 at 4:21 PM ยท edited Thu, 20 February 2025 at 2:01 PM
does anyone out there have any half underwater scenes or tutorials that I can download. Thanks
niandji ( ) posted Mon, 14 February 2005 at 4:46 PM
Check out the Backroom - the link is at the top of the page - there's a tutorial by sacada that should meet your needs exactly.
kevin_c ( ) posted Thu, 17 February 2005 at 2:30 AM
I tried this tutorial last night and it was pretty easy to get the water plane into position and achieve the right effect on and above the water but I was confused about how to make the area below the water level actually look like it's underwater. Sacada (or anyone else), can you explain how it's done. Thanks.
sacada ( ) posted Fri, 18 February 2005 at 12:37 AM
Light is the effect that produces the underwater look. Two main ways that can be used independantly or together. Volumetric spotlight and a Gel. I usually use the Spots Gel or the Caustics Gel in the Light Gels Material Group. Make sure your light is below to water line to get more control.
kevin_c ( ) posted Fri, 18 February 2005 at 1:55 AM
Thanks sacada. I'll give that a try.
