Fri, Dec 27, 3:01 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
Subject: NEED HELP... whered it go?!
DigitalDreamsDS ( ) posted Thu, 17 February 2005 at 8:23 PM ยท edited Fri, 27 December 2024 at 2:56 AM
Ok, everything was fine... started up poser and now when I go to materials.. the document window is no longer showing up!
WHAT DO I DO?!
Little_Dragon ( ) posted Thu, 17 February 2005 at 8:34 PM
For starters, turn off Caps Lock.
Then, try this:
Window menu --> Show All Tools
Not sure about the document window. It may be hiding behind the material pane or Library panel (try moving them to see), or it could be offscreen. Double-clicking on the document window's title will hide the window itself, but I don't see the title itself anywhere in your screenshot. You might need to relaunch from a factory state to get it back, if you don't have the UI stored in your memory dots.
