Wed, Feb 19, 1:50 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: not sure what to call this script :)
anxcon ( ) posted Sun, 13 February 2005 at 3:42 PM ยท edited Tue, 11 February 2025 at 3:40 AM
k a script idea first the limitsa modeller would need to stick to in order for script to work right all vertices must stick to an X,Y grid with 0.1 increments 0.5, 0.4, 0.3, 0.2, 0.1, 0.0, -0.1, -0.2, -0.3, -0.4 etc X,Y be to a max of +/- 50.0 so center and 500 each way the file from script would be 1001x1001 pixel so 501x501 is 0.0 then Z coords of a vertex can be 0.00000000 to 1.00000000 (think model files goto 8 points right of demical?) any increment k script works like load vertex (X, Y, Z) pixel (501 - (X * 10)),(501 - (Y * 10)) = roundnearest(255 * Z) //R G B are same value, output above makes a greyscale map //which shows Z coords "depth" 0-255 pic loop till no vertices left save image exit script ignores edges/faces/etc, only looks at vertices would require limits on modeling, but i can work with that want to try mr ockham?:)
anxcon ( ) posted Sun, 13 February 2005 at 3:54 PM
and before looking at model, creates a "starting" pic named "empty.bmp" unless one already exists (incase of deletion or something perhaps? be a one time thing tho) with all pixels set to 0R/0B/0G the script opens that, then the pixels with no vertex have a default "0" value to start with
ockham ( ) posted Sun, 13 February 2005 at 4:01 PM
Seems possible, but I'm curious about the highly specific formula. What's the main purpose?
My python page
My ShareCG freebies
anxcon ( ) posted Sun, 13 February 2005 at 4:03 PM
mmm........nothing :)
underdog ( ) posted Sun, 13 February 2005 at 6:40 PM
[DrMcCoyVoice]My god! I think he's building a tesseract, Jim![/DrMcCoyVoice]
[MrSpockVoice]Fascinating![/MrSpockVoice]
:-P
anxcon ( ) posted Tue, 15 February 2005 at 10:52 AM
ockham dont want to make -.^ im hurt
underdog ( ) posted Tue, 15 February 2005 at 9:40 PM
Can't really blame him without some kind of clue as to the usefulness. What does it do?
anxcon ( ) posted Tue, 15 February 2005 at 11:18 PM
ah fine fine i make a flat square in a modelling program, say blender the square is whatever vertices wide and high then i move them along Z scale to make a shape lets see how smart you are :) whats a greyscale map do that is showing "depth" info? if you said displacement maps, you get it right now this is only part of it the image produced is often just 1 part of the model has to be made piece by piece then pasted over the UV template for the end figure thus the end result is an easy way to create accurate and high detail dis maps with perfect shape now doesnt need to be in poser, can be its own program just needs to read obj files and output the bmp file its also good for trans maps
anxcon ( ) posted Thu, 17 February 2005 at 1:45 AM
booo...
an0malaus ( ) posted Fri, 18 February 2005 at 8:14 AM
Are you making a pin-map? Regular grid of planar vertices displaced in Z by topology of whatever's behind the grid... BTW, I'd love to see a folded tesseract [assuming I could survive the experience] ;-)
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
