I'm only really posting to emphasise the point. If your simulation has not started within 5 minutes then cancel and find out what is wrong. There is no point in letting it run longer any longer. Most probable cause as mentioned above is that some part is intersecting the figure. Other possibilities may be poorly formed mesh, n sided polygons or very long thin polygons, a turned in cuff that now has the polygons facing the figure rather than away from it.
Well, the three tutorials I have used are the ones from the Poser 5 manual, the Poser 5 handbook, and HMann's clothing tutorial. For all, the steps are basically the same: 1. Add a figure (either Vicky or Judy). 2. Add a dynamic clothing prop (for Judy I used the Beach Dress). 3. Zero Pose Judy/Vicki in frame 0. 4. Choose the final pose I want in a later frame (15 in some cases, 30 in others, or using HMann's tutorial, just a 6-frame animation, which has worked in the past). 5. Create a new simulation. 6. Simulator settings: In some sims I have left it at zero drape frames, in others I set 20 drape frames, though as I understand it this is not necessary for most props, if there isn't a lot of draping (like with a T-shirt). If I click the "Calculate Drape" button I get the same result as for "Calculate Simulation": it just runs forever. 6. Clothify the clothing prop. Add Judy/Vicki as the object to collide against. I've tinkered with decreasing the collision offset and depth settings, I've done it with and without "Start drape from zero pose," I've set it to ignore hand, head, and feet collisions. 7. Calculate Simulation. And wait forever.
Here is my latest headache -- I cannot get Poser 5 to perform cloth simulations. I am using dynamic cloth props and trying to drape them over a figure. I have done this in the past, and it worked fine. For some reason, now when I start calculating the simulation, it just runs and runs but never finishes. (I have left Poser running overnight, just to be sure that I wasn't being impatient -- and this is for simulations that in the past have taken no more than 10 minutes or so. The next morning, it was still "calculating" without any output.) I've gone through several of the very basic cloth room tutorials step by step, just to make sure I hadn't missed something, but the result is always the same. Endless processing time, no simulation.
