Wed, Jan 22, 10:58 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2025 Jan 19 8:07 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Abnormal Normals
jestmart ( ) posted Mon, 21 February 2005 at 2:24 AM · edited Tue, 21 January 2025 at 2:51 PM
Based on the behavoir I noticed of renders done in DAZ Studio using a model made with Blender, I believe the normals are not being set right. I brought this up in another forum and recieved a reply confirming this, however no one seems to concerned about it. Is there a fix or work around that I don't no about. UVMapper Pro appears to fix the problem when I use Normal/Smoothing tool but the demo doesn't allow saving the model so I have no way to confirm whether the fix is a fix. Can any one help me?
ysvry ( ) posted Mon, 21 February 2005 at 10:37 AM
u did try the ctrl n recalculate normals option?
for some free stuff i made
and for almost daily fotos
jestmart ( ) posted Mon, 21 February 2005 at 10:42 PM
It is not a matter of them being turned wrong, it is that they are not being set perpendicular to the face. I was testing reflections in DAZ and this is the only explaination for the results I was getting. It may be messed up by the new feature that Blender has to control the directions of the normal by using color displacement maps.
dhenton1000 ( ) posted Tue, 22 February 2005 at 1:00 PM
Can you post a picture showing the problem? I know that OBJ output from Blender is sometimes an issue for normals.
jestmart ( ) posted Wed, 23 February 2005 at 10:20 PM
This is how it looks and renders in blender with "Auto Smooth" on and set at 15 degrees
jestmart ( ) posted Wed, 23 February 2005 at 10:22 PM
This is how it looks and renders in DAZ Studio.
jestmart ( ) posted Wed, 23 February 2005 at 10:26 PM
I loaded model into UVMapper Pro demo and got some promising results. This first image is how model looks upon loading.
jestmart ( ) posted Wed, 23 February 2005 at 10:30 PM · edited Wed, 23 February 2005 at 10:37 PM
This image is also in UVMapper after using its Normals Tool to set "Auto Smoothing" again at 15 degrees. The problem is the demo doesn't allow saving of the model so I don't know if the change will carry over to Studio. Just to be thorough I built the model in Wings 3d also. It looked fine in Wings but looked much the same as the Blender model when viewed in Studio. As I write this I realize I didn't opening Wings obj file in Blender to see what would happen, I'll try that tomorow.
Message edited on: 02/23/2005 22:37
dhenton1000 ( ) posted Thu, 24 February 2005 at 8:03 AM
Take a look at poseray instead of UVMapper http://user.txcyber.com/~sgalls/ I had this same problem and use Poseray to fix it. Poser auto smooths everything, so to get a straight edge you have to split the vertices, which pose ray does. I'm pretty sure that the default obj export on blender would bring out the proper smoothing, but poser won't recognize the flat regions. HTH
