Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
Not sure what you mean by it works on a cube in the lab but not on the real thing. Could you post a screen shot of the lab settings you're using on your wings model? One thing I can think of, is if the third box in the lab doesn't have any bump texture, like if its a solid grey then you won't get any bump no matter what number you set the bump to. Same if the dot isn't in the right channel. but without a screenshot I've got no idea :(
For the oment Ive ignored the problem and rendering at the moment.. What I meant was that in the lab, everything looks good on the preview on a cube or cylinder and so on.. I cant prewiev on the "real thing" because its quite small.. but when I go back to the real set no bump is working.. infact if I choose to use it as a texture it doesnt work either.. have a clue that it has something to do with the sixe of texture Ive tried to change to alot of diff. sets. but nothing helps...
"Guns
don´t kill aliens, big steampowered weapons kill
aliens"
Have run into a strange problem.. and I just cant get it right.. I wanna put a bump onto a button made in wings.. Its just a square and the only bump on the modell so I dont Uv map anything just makes a squarish bump map that should fit.. I choose the bump and set bump to 100.. works fine in the lab with a vube and everything but when I go back to the real set nothing happens.. have never run into this problem before.. anybody knows how to get this working?
"Guns don´t kill aliens, big steampowered weapons kill aliens"
