Forum Moderators: RedPhantom
perhaps if you can do something with the transparency? (Know how to do it in Bryce, but that's no help..;), maybe up the reflectivity, if that's not mutually exclusive..better answers coming after this one..;)
Transparency would definitely help both the diamonds and the ruby--neither stone is solid-colored. Which version of Poser are you using? Poser 5 has a transluceny node which may actually be better than the transparency. I wish someone would create a set of Poser 5 materials for gemstones that look realistic.
if transparency is set to anything other than 0 then the ruby is gone, all thats left is the specularity area which is ghosty used refraction and reflection only to make it the best glass ive seen is refraction/reflection only with transparency set to 0, and gems are basicly just the same thing as glass, just different values ya im using P5, just cant seem to get material right
You almost need a faceted reflection map to give the illusion of being cut but I do not know where to find one. Check around in your reflection maps for one called diamonds. I'm not sure what set mine came with but I have attached that to the reflection map and to the diffuse map with so-so results. I posted a wishing well message for someone to make a set of Poser 5 gemstone materials.
Yeah, you'd need some map to give the illusion of facets, otherwise, you can get the gem model is a cabachon cut.
Weapons of choice:
Stuck in a render or I'd test this before I post, but in P5 with Firefly renderer, you could perhaps turn off smoothing for the central stone and see if that affects the rendering of reflections from its surface (turning its polygons into facets).
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
Attached Link: http://www.3dlapidary.com/HTML/Stones1.htm
There is a Poser4 diamond prop on this site's page (kindly provided by Robin Miller) which has a image map of the facets...which can probably be easily converted to any shape if you have something like Photoshop or PhotoPaint etc. You may have to do some tweaking in P5 for the tranparency tho....forgot to say, it's at the bottom of the page... And yes, definitely 'unsmooth' the model. Poser and many other rendering programs tend to smooth things automatically, 'cause they're oriented to organic-looking models. Sharp edged facets, though, are necessary for cut gems.
got this pretty heart in free stuff:) trying to get it ruby heart and rest diamond i think ruby is just about right, what you think? but i cant get diamind to show right, help?>_> seems like problem with specularity but everything i change for spec doesnt seem to be doing much so dunno :S
