Sat, Jan 11, 3:44 AM CST
Subject: Problem with Vue5 render. Anyone seen this before?
HellBorn ( ) posted Sun, 06 March 2005 at 7:25 AM ยท edited Sat, 11 January 2025 at 12:52 AM
I have some problem rendering a model I'm working on. I renders very strange in Vue5 but works perfectly in Vue4Pro.
This is the Vue5 render
HellBorn ( ) posted Sun, 06 March 2005 at 7:26 AM
And a closeup of the Vue5 render
HellBorn ( ) posted Sun, 06 March 2005 at 7:27 AM
And a Vue4Pro render without the problem.
wabe ( ) posted Sun, 06 March 2005 at 11:16 AM
Looks like an import problem. You should report this - with the renderings and the technical details (import file format etc) You can try to triangulate the model in the program you do the modeling and try again.
HellBorn ( ) posted Mon, 07 March 2005 at 12:45 AM
Triangulating in my model app was my first fix to this problem. However, in order to save on the geometry in the modelling app I did rather locate the problem areas and rebuild them manually. So, now I know that the problem is created by polygons with 5 or more vertices, something that can create problems for some applications. But, as import worked in Vue4Pro I do expect that it's supposed to work in Vue5 as well so I will report the problem.
HellBorn ( ) posted Wed, 09 March 2005 at 2:30 PM
The problem have been fixed in the current Beta version.
