Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 7:46 am)
Poser will do a check on your LAN (if you have one) to ensure that no other copies of the program are running with the same serial number. It will only access the Internet if you use the Content Room. ZoneAlarm can not differentiate between these two operations and hence gives you the message you see.
I have Zone Alarm set to allow Poser through automatically. If you don't let it do its serial number check, it will keep trying - again and again and again, eating up system resources. Let it through, and it will check once, and not try to check again until you re-start Poser. (P4 does the same thing, BTW, even though it has no Content Paradise.)
Once you get the permissions set for each app that may try to contact the net, (and you will be further surprised at which ones do, i.e. wordpad?) ZoneAlarm will stop bugging you unless something is truly amiss. You can also turn off the normal alert pop-up windows and just log them instead. (usually no need to be interupted everytime your IP address gets pinged).
Attached Link: http://poserpros.daz3d.com/forums/viewtopic.php?t=16569
"How to Remove Content Paradise" PoserPros>forums>Poser 5 Tips and Tricks. But it doesn't work for me(Poser can't start because of xml error). HatsumiThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hello community.I have recently installed a dem of a program called Zonealarm,and it sees who what when where why how of internet activity on the pc.Well for some odd reason it sees Poser and Vue both as attempting to access the internet upon start up.Interesting i thought because i dont see why they would need the internet at all.Is this some form of violation? maybe it is a program flaw? Has anyone else experianced this sort of thing?
