Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Two problems - first, the size of the V3 figure can be too much for Wings. The solution to this is to only export the bits you need - select a subset and exclude the head, hands, fingers and feet unless you really need them. These are where the majority of the problems occur. A second problem is that Wings tends to split V3 into dozens of tiny groups, so if you do get V3 into WIngs you will need to select all and combine to produce a useable figure.
yup..Wings tends to gag on larger file size imports. Another option is perhaps using Vickie Lo-res, or possibly a (is there an equivalent of Mike 2 body, Mike3 head for Vickie?) anything to cut down on the file size..
I know, I know, we have a wings forum here too. I posted this there as well, but no one was answering so I thought I would try my luck here. Why can't I import the V3 figure into wings? Wings will start to read it and get almost all the way to 100 and then just stop. Its quite frustrating, really! Ebil
