If you are trying to superimpose a Poser figure onto a photo, choose FIle > Import > Background Picture. It will ask if you want to change the document window to match the background picture. If you answer yes, the document window will change dimensions to match the background picture. If you answer no, the document window will remain the present size, but the background picture may get distorted.
Message edited on: 03/20/2005 13:46
Chromakey is a particular (and old) video process, and from the software you mention, it does look as though you're talking about video rather than individual photographs. For a static background, Deecey's method should work. Am I correct in thinking you want the background to be some sort of moving picture?
I created an animation of ten figures marching with ground shadows.I want keep the ground and figures and change the background. arrow1
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
chromakey is an overlay process where the selected color is made transparent. There are other methods if you are doing still images. Microsoft movie maker with XP sp2 has the capability but the color used is very specific. Sony vegas movie studio 4.0 does it better with a wider color range. (shades of the same color) Premiere Pro will certainly do it, its one of the video standards.
If you're sure it's chromakeying you want, Zwei-Stein from Thugsatbay.com has easily the most flexible implementation I've seen, and it's free! On the downside it has a bizarre, and frankly ugly, interface and it doesn't support 16:9. Also you can use the alpha channel in an animation if you render out to a numbered sequence of TIFFs or PNGs.
Message edited on: 03/20/2005 16:11
Attached Link: http://www.bauhaussoftware.com/home_LP.php
Chroma key is only nessisary when using a live action source shot in front of a green/blue screen.The easiest and cheapest way to composite in this case to simply import your video into poser as a background (Poser 5/6)
I still use that simple technique with Truespace to add Lens flares to my animations. :D
You could do it with a photoshop action and Poser figures rendered with an alpha channel.
If you want more control and have around $800 burning a hole in your pocket I can never reccomend Bahaus software's Mirage enough, as a compositing/FX/paint solution. Oh, and it can also do chroma keying if you ever want to make your own Blue screen and do some cool VFX for your home movies. :D
Message edited on: 03/21/2005 10:29
Does anyone know how to chromakey a Poser figure onto a background? And can this only be done in Adobe Premiere Pro or elements? These programs are quite expensive!I have read several articles on this subject, but they are too general.I was wondering if someone would be kind enough to take me through the process step by step.Cheers arrow1
