Thanks for your thoughs.
As far as the wings go, I'm really not happy with them at the moment, I plan to use Faceoff's tutorial for SSS and I'll take a look at Catherina's gallery it may inspire me.
ventral plates - check, I can just use the body texture and blend it in. I may even be able to get away with a blender node trick.
Horns are just using a canned Poser texture so yea they could use some work on wear and tear for now we'll just say it's a young dragon ;) what do you guys think about perhaps a trace amount of translucence to the horns as well. I've observed that some peoples teeth, even though they take good care of them, for one reason of another have a little bit of a translucence quaility to them, any one concer?
I was accutally inspired by the Animal Planet commercials a little while back, but waited until after the special to make some obsercations on how they did things. Strange huh, most people watched the show to learn a little more about dragons and if they could of existed. I on the other hand watched it to pick up tips on texturing. Am I alone in this? :)
Ohh BTW I plan to wrap this up into a mat file and stick it in the freebies section when I'm done, so all your suggestions will make a better free product for all of us to use
Message edited on: 03/21/2005 09:57
The only usage restriction will be that you can't pack the texture up and sell it as your own (not that you couldn't pack it up and GIVE it to people free just a by line is all I ask), anything else would be cool.
as far as the special goes. I found it intertaining, I'm not a big dragon 'specialist' so I can't really comment on the way they explained things from a historic sense. I did however find the 'dragons as big hydrogen ballons' bit a little hokey, and the fact that they 'could' explode on inpact if they were using the fire weapon and crash hard enough. Although that would be a sight to behold. yea I noticed the palms after I rendered this, I'm using crocodiles as guidence more then Geckos and the smaller lizards, but the change still applies just not as small. They also tend to be a bit lighter in color then the tops of the hand so I'll probably use the belly coloration in them.
Ohh BTW perhaps I'm just being retarded today but I can't seem to find Catherina's gallery or what randym77 was talking about, any one have a link or something that I can follow
Message edited on: 03/21/2005 10:26
Message edited on: 03/21/2005 10:29
Try here, thixen:
http://www.renderosity.com/messages.ez?Form.ShowMessage=2105489
Get comfortable, it's a long read.
Any Suggestions? -- note the weird green glow to the mouth is a weird lighting thing. I just used a quick lighting set so it needs tweeked.
Message edited on: 03/21/2005 07:55
