Thu, Jan 23, 1:31 AM CST
Forum Moderators: Staff
Subject: Bugs with magnets
Cage ( ) posted Mon, 15 January 2001 at 1:41 AM · edited Wed, 08 January 2025 at 4:17 AM
I have a hair figure with a magnet more-or-less permanently parented to it. Over a couple of months, I have saved and re-saved this figure, moving it from one .cr2 or .pz3 to another. I have ended up, in the course of this, with multiple magnet references listed under the affected body parts. Some parts have five or six references to this same magnet, all of them fully functional. On the other hand, I have another figure with a similarly semi-permanent magnet attached. In this second instance, the magnet will lose functionality altogether in some .pz3's or .cr2's, while functioning normally in others. Once the magnet "goes dead", it seems to stay dead, regardless of whether I re-save the file. Is there something I can do to counter this, or is this a limitation of Poser? Perhaps magnets are not supposed to be imbedded in files?
JeffH ( ) posted Wed, 17 January 2001 at 3:58 PM
Save the Mags to the Props library using the subset, then you can apply them to any new version of you files. I usually spawn MTs instead of keeping the magnets attached perminently.
Styxx ( ) posted Fri, 19 January 2001 at 12:26 PM
thanks jeff! you answered my question too :)
Cage ( ) posted Fri, 19 January 2001 at 7:41 PM
Thanks, Jeff. I hesitate to save the former magnet to the library. The hair figure has twenty locks, each of which would have to be re-associated with the magnet. Eep. Good advice for the other magnets, though, definitely.
