When the Daz installer starts its search for Poser click on the cancel button. It should, their installers are sloppy, ask for a path. Select your path here and install to it. I use a path Poser Test New Items and it usually finds that each time once it been set the first time. Once installed there I usually run Correct reference on the files before moving them to a more permanent spot.
The important thing is not to stop questioning.
- Albert Einstein
Indoda
thanks for that. This problem has really bugged me! Would've thought the installer would be more efficient.
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
wonder if anyone else has had problems here. I've got P4 with Pro Pack. I've got a bit of stuff from Daz's March Madness promo and duly installed it. However, some of the files appear to be all over the place in the runtime sub folders. If I try to apply MATS they don't always work. I'm considering using P3do to sort things out. Can I direct the installer to put the stuff in a separate folder (made for the purpose) and transfer the files manually? I know how and where to do this. I usually do this with freestuff zipfiles with little or no trouble. TIA
Gallery
Freebies
Music Vids
