Tue, Feb 11, 4:06 AM CST
Subject: Poser Newb - Needing help installing
Loktera ( ) posted Fri, 25 March 2005 at 12:17 AM ยท edited Sun, 26 January 2025 at 11:32 AM
I need help in installing a few things. Namely the Aiko, Victoria, and Micheal models. I just need to know where to install them. If you can't tell I am new, and appreciate any help given. Thank you much, Loktera
Mariana_ ( ) posted Fri, 25 March 2005 at 1:47 AM
click on the Exe icon that you download from Daz3d.com and it will install itself to the proper directories hon :)
Loktera ( ) posted Fri, 25 March 2005 at 3:31 AM
I've tried... But it installs itself to where ever the .exe was downloaded to... Maybe I'm not doing something right...
yggdrasil ( ) posted Fri, 25 March 2005 at 3:54 AM
Attached Link: http://www.daz3d.com/support/faq/index.php?id=61
The DAZ installer will prompt you for a directory part way through the process. If you installed Poser to the default location (on PC) then this will be **c:Program FilesCurious LabsPoser 6** (or 5 or 4 depending on which version you have).
If you let it the installer can search for this folder for you, or you can use the browse button to find it yourself. Older and more recent versions of the DAZ content installers have different appearances and options, but the basic process is the same.
Mark
Loktera ( ) posted Fri, 25 March 2005 at 4:16 AM
Oh.. hehe... I found out where I screwed up.... Wow... I've spent so much time over the past few days learning this program I haven't got much in the way of sleep. Very easy to overlook the obvious. (Spring Break, what else am I going to do? Party?)
Mariana_ ( ) posted Fri, 25 March 2005 at 6:12 PM
eek sorry shoulda added that bit in there i think i assumed yours would auto because mine did into poser directory, glad ya got it workin :) and woohoo party ^.^
