Thu, Nov 28, 4:27 PM CST
Subject: Problem with V3 morph INJ on P6
Vestmann ( ) posted Thu, 24 March 2005 at 8:14 PM · edited Thu, 24 October 2024 at 6:12 AM
I decided to re-install P6 on another drive along with everything in my old Runtime. Now, when I inject V3's morphs, Poser cant find'em. Ive tried moving the !DAZ folder into the Pose folder but nothing works. Can anyone help me out? Poser ain't the same without the main star :)
 Vestmann's Gallery
Tyger_purr ( ) posted Thu, 24 March 2005 at 9:12 PM
um. your !DAZ folder should be in your ...Runtimelibraries not in the Pose folder. or is that where you put it?
My Homepage - Free stuff and Galleries
Vestmann ( ) posted Thu, 24 March 2005 at 9:16 PM
It's in the libraries folder and I put in the Pose folder (Copy)
 Vestmann's Gallery
Vestmann ( ) posted Thu, 24 March 2005 at 9:21 PM
The thing is I cant load "!All morphs" for head or body and I cant load INJ poses from character sets..
 Vestmann's Gallery
bevans84 ( ) posted Thu, 24 March 2005 at 10:20 PM
Have you tried rerunning the .exe? Don't know if it would help because the pz2's look to have valid file paths regardless of the drive, but you never know. I have both P5 and P6 on my F drive and just pointed the P6 library to the P5 runtime. No problems.
svdl ( ) posted Fri, 25 March 2005 at 8:11 AM
Ah, the dreaded All Morphs issue. The reason you can't use them is that they reference the individual pose files in your Pose library, instead of the INJ/REM and channel poses in the !DAZ library. I've edited the All Morphs pz2 files to pick up the poses from the !DAZ folders, instead of the library pose folders. Problem solved. (Did this in P5, I didn't like the default library organisztion the head and body morph pack installers created. Works in P6 too).
My gallery   My freestuff
Vestmann ( ) posted Fri, 25 March 2005 at 8:16 AM
Ahh... Thank you svdl. Ill try that.
 Vestmann's Gallery
RHaseltine ( ) posted Fri, 25 March 2005 at 8:49 AM
If the All Inj/Rem poses are still pointing to the Pose library folders rather than the !DAZ folder then you are several updates adrift. Redownload the morph packs (since the updaters are still AWOL) and all should be well. You might also want to redownload V3, in case you are behind there too.
