Sat, Jan 11, 7:11 AM CST
Subject: Newbie Question: P6 - AO, IBL, Shadow Catcher.. Whats that?
Eismaus ( ) posted Fri, 25 March 2005 at 9:58 AM · edited Mon, 06 January 2025 at 5:58 PM
I have been reading the words AO, IBL, Shadow Catcher for a few days now. I know, that this are new functions in poser. But, what exactly are they?!? Can someone explain? Thanks Eismaus
nerd ( ) posted Fri, 25 March 2005 at 10:19 AM
Forum Moderator
AO = Ambient Occlusion = A very subtle way of shading objects. The shadow effect if very similsr to global illumination. IBL = Image based lighting = The scene is lit based on an image map. Using a light probe (a 360deg photo of a real scene) your Poser scene can be lit exactly like it was in the real world. Shadow Catcher = A new function in the material room that allows an object to render invisible but shadows will still be cast on it. Very handy for compositing Nerd3D
slinger ( ) posted Fri, 25 March 2005 at 10:20 AM · edited Fri, 25 March 2005 at 10:21 AM
Attached Link: http://www.planit3d.com
AO = Ambient Occlusion AO makes figures and objects appear as though they are in a natural lighting environment, thus providing a new degree of realism. AO darkens surfaces within a scene whose exposure to light is blocked by other objects. This effect uses raytracing to calculate the degree to which other objects within a scene occlude the ambient light of a surface at a given point. Surfaces with more occlusion will be rendered as darker than surfaces with little or no occlusion. Just to remind you, all the images we're using here have their shadows raytraced in Firefly. Some features (like Point Lighting) can't use the old Depth Mapped Shadows so we couldn't compare the various iamges fairly if we mixed them up.
IBL = Image Based Lighting
Diffuse Image Based Lighting (Diffuse IBL) takes a light probe, which is ideally a 360 degree light distribution captured in a single image map, and illuminates the scene using that map. In Poser, only the diffuse component of the light is defined by the light probe. As this technique is based on complete light data for a given space, the lighting results can be very realistic. In order to get realistic shadows when using an image based light use Ambient Occlusion.
NOTE: For ambient occlusion to work you must set the shadows to Raytrace on your light(s)
The Shadow Catcher...
...allows transparent surfaces to catch shadows, as opposed to letting the shadows appear on the opaque surface behind them. In other words, this option will treat transparent surfaces as opaque, only in terms of their interaction with shadows. A prime use of this feature would be if you wish to render only a figure and its shadow; you could set up the floor as a transparent surface by using the ShadowCatchOnly feature to show your figures shadow on the transparent floor, and render (without the background). The floor will be invisible except for the shadow laying on it, so the only things in your rendered scene will be the figure and its shadow.
You can check out some examples and mini-tuts on all of these (and more) in our Tutorials forum over at PlanIt 3D
[edited to admit to being a day late and a dollar short thanks to Nerd ~lol~]
Message edited on: 03/25/2005 10:21
The liver is evil - It must be punished.
PhilC ( ) posted Fri, 25 March 2005 at 10:23 AM
Attached Link: http://athens.ict.usc.edu/Probes/
Read all about IBL, Image Based Lighting at the above link. I like it ... a lot :)
There are a number of light probes you can download for use in Poser 6. You may also find the HDRView utility useful on that page.
Eismaus ( ) posted Fri, 25 March 2005 at 10:31 AM
Wow, thanks for the fast answers and the links. I'm going to read them :o) Eismaus
operaguy ( ) posted Fri, 25 March 2005 at 10:41 AM
we are all having immense fun with this stuff! Love it. I want to know more about the files that can serve as the reference source for IBL, but will read links above first. ::::: Opera :::::
Nance ( ) posted Fri, 25 March 2005 at 12:00 PM
bookmark (grumble-grumble. Stuck with merely reading about the new tools as yet have nothing to play with)
unzipped ( ) posted Fri, 25 March 2005 at 6:36 PM
bookmark also
hemi426 ( ) posted Tue, 05 April 2005 at 11:13 AM
bookmark!
