Thu, Jan 9, 12:06 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 08 11:53 pm)
Subject: Need help ASAP/ Poser won't start up!
ebil ( ) posted Thu, 24 March 2005 at 12:08 PM ยท edited Wed, 08 January 2025 at 7:37 AM
My poser won't start up it acts as though it is going to open but then it just doesn't. I ran a virus check, but nothign came back. Anyone know what to do?
DCArt ( ) posted Thu, 24 March 2005 at 12:12 PM
Attached Link: http://www.curiouslabs.com/article/articleview/1392/1/595/
Here you go ,,, see if this helps.
constantine_1234 ( ) posted Thu, 24 March 2005 at 12:42 PM
Do you indeed have Poser 6? If so, the above-mentioned link might be appropriate. However, if you don't have Poser 6, I might ask what version do you have? I've had this problem with Poser when on a network. My wife had the printer hooked up to her computer. I'd turn off her computer to save electricity, and Poser would not run because it couldn't find my wife's printer. Poser never said exactly what the problem was. Maybe that applies to you?
caulbox ( ) posted Thu, 24 March 2005 at 12:55 PM
If you're using Poser 5, then is it another possibility that you may have re-named or re-located any of your P5 runtime libraries? If so, you might try deleting (or temporarily re-naming to be safe) LibraryPrefs.xml in the prefs folder. P5 will create another one. From my own experience with P5, I can tell you that I use about 20 different runtimes, and sometimes if I (foolishly) re-locate or re-name a few on my hard drive (outside of Poser, and without deleting the libraries from P5 first) then I get a similar problem to the one you describe (XP actually chips in to tell me there's a problem when loading). The problem is fixable if I delete LibraryPrefs.xml. If deleting the file does help cure the problem, it'll be necessary to add your runtime libraries to Poser 5 again - but at least you'll be up and running.
CorwinRathe ( ) posted Thu, 24 March 2005 at 1:01 PM
I had a problem with Poser 6 crashing right to the desktop. But this was fixed when I downloaded a new version a drivers for my FireGL card.
ebil ( ) posted Fri, 25 March 2005 at 1:35 PM
Sorry, it was P5 I just had to reinstall it and all works now. Sorry If i do't reply much just had another major surgery so I won't be on much, but I have had a lot of time to work. Thanks
constantine_1234 ( ) posted Fri, 25 March 2005 at 6:38 PM
I'm glad Poser is working for you now. You take care of yourself.
